You asked for it!!!!
R. Alternative Energy Systems
Alternative energy systems, including wind, solar and geothermal, may be used where allowed within
a zoning district, provided that they also comply with the following conditions:
1. Wind Energy Systems:
The following general regulations apply to all wind energy systems located within an
approved district.
a. General Regulations. The following general regulations apply to all Wind Energy
Systems located within any district.
(1) Utility Grid Wind Energy Systems are prohibited within the City.
(2) Building Permit Required. A building permit must be obtained prior to the
construction or installation of a Wind Energy System. An application for
building and electrical permit must be accompanied by:
(a) The appropriate permit fee as established in the City’s Fee Schedule;
(b) A site plan of the proposed Wind Energy System at a scale of 1" = 30'
or larger. The site plan should be on a single sheet (not exceeding
24” by 36”) and include:
(i) A survey and legal description of the proposed Wind Energy
System;
(ii) A plan view layout of the proposed Wind Energy System
clearly showing:
• the location of the wind energy system in respect to the
property on which the system will be built,
• All components of the System;• the distance from the system to all property lines,
• Required setbacks;
• Adjacent land uses and zoning designations;
• Existing structures on the site;
• Required landscaping or screening of the base of the
tower structure; and
• Natural features such as watercourses and trees.
(d) Elevation drawings showing:
• The design and height of the proposed Wind Energy System;
• Detailed drawings of all System components; and
• Screening requirements.
(e) A line drawing of the electrical components of the System in sufficient
detail to allow for a determination that the manner of installation
conforms to the National Electric Code. This information is
frequently supplied by the manufacturer;
(f) Standard installation drawings of the wind turbine structure, including
the tower, base, and footings. If the system is mounted on a tower,
either an engineering analysis of the tower or a copy of the
manufacturing specifications demonstrating compliance of the
system with the City’s building code (International Building Code) in
effect at the time of construction. An engineering analysis shall be
provided and certified by a registered professional engineer in the
State of Texas. This analysis is frequently supplied by the
manufacturer. Wet stamps shall not be required.
(g) Evidence of notice to the City’s franchised electric utility for
transmission and distribution, informing the electric utility of the
customer’s intent to install a grid-connected customer-owned wind
energy system and that the customer’s system meets the utility’s
approved specifications for interconnection.
(h) Proof of insurance coverage as required in Subsection (16) below.
b. Construction Standards. A Wind Energy System must be installed according to the
manufacturer’s recommendations and under the seal of a professional engineer
registered in the State of Texas. Additionally, all components of a Wind Energy
System shall comply with applicable state and Benbrook building codes.
(1) Maximum Height. The tower height shall not exceed the maximum allowed
within the zoning district, or as permitted by a conditional use permit.
Additionally, no tower height shall exceed the tower height recommended by
the manufacturer or the distributor of the Wind Energy System. Any towers
that exceed one hundred feet (100’) in height must obtain a letter of no
objection from the Commanding Officer of the NAS Fort Worth JRB.
(2) Location and Setback. The tower structure of a Wind Energy System must be
at least 40 feet from any primary structure and may be no closer to the
property line than the highest point of the system, including the maximum
height of any blades when attached thereto. No part of the Wind Energy
System, including blades or guy wire anchors, may extend closer than 10
feet to property line or within any required yard setback.
(3) Primary Structure Required on Lot. A Wind Energy System may be erected on
a lot only after a primary structure has been constructed on the lot.
(4) Sound Pressure Levels. Sound Pressure Levels shall not exceed 50 decibels
(dBA) between the hours of 7:00 a.m. and 10:00 p.m. and 35 decibels (dBA)
between the hours of 10:00 p.m. and 7:00 a.m. as measured from the
property line closest to the Wind Energy System.
(5) Lights. All lighting not required by the FAA is prohibited. When obstructionlighting is required by the FAA, such lighting shall not exceed the minimum
requirements of said agency. A tower structure may be artificially lighted
ONLY with steady-burning red obstruction lights (FAA type L-810) or
flashing red obstruction lights (FAA type L-864) flashing no faster than 20
flashes per minute. Flashing red obstruction lights (FAA type L-864) flashing
faster than 20 flashes per minute, medium intensity flashing white
obstruction lights (FAA type L-865 or L-866), high intensity flashing white
lights (FAA type L-856 or L-857) or dual flashing red obstruction lights and
medium intensity flashing white obstruction lights (FAA types L-864/L-865)
may be used ONLY when the FAA specifies that the specific lighting pattern
is the ONLY lighting pattern acceptable to promote aviation safety and
refuses applicant’s request for authorization to use the lighting required by
the City herein. Upward lighting, flood lights or other lighting not strictly
(6) Signs. No advertising or other signs shall be allowed on a Wind Energy
System.
(7) Prohibited in Easements. No portion of a Wind Energy System shall be placed
in easements unless authorized by the easement holder.
(8) Screening. A Wind Energy System shall be screened from view from adjoining
properties by solid fencing or evergreen plants to a height of at least six (6)
feet.
POST TOO LONG.....CONTINUED ON NEXT POST.....
