2006 IRC-section R703.8 Flashing This section states "Approved corrosion resistant flashing shall be applied shingle-fashion in such a manner to prevent entry of water into the wall cavity or penetration of water to the to the building structural framing components. The flashing shall extend to the exterior wall finish or to the water-resistive barrier fo subsequent drainage."
I just did a housewrap inspection and the windows were flashed with tape only. I would prefer to see actual metal or plastic additional flashing, but the manufacturer's instructions only mimic the code language and are not specific about materials to use.
My question is: Do you consider This to be properly flashed? What about if it is 2 units mulled together with an additional piece of plastic covering the joint for 1 inch on each side of the joint? These are vinyl windows.
