We have a very large, newer building here in Alaska that has been vacant for several years. Only 6 years old and vacant for 3.
The gas and electric utility bills to maintain heat are thousands of dollars per month.
The only reason the heat is maintained is to keep the code required sprinkler system from freezing.
Should we allow the system to be shut down, drained and winterized along with all other plumbing systems so heat will no longer be required?
The building is of unlimited area 131,000+ and surrounded on all sides by hundreds of feet.
