do they meet ::::: because of the remodel is not that extensive????
4603.7.2 Interconnection. Where more than one smoke
alarm is required to be installed within an individual dwelling
or sleeping unit, the smoke alarms shall be interconnected
in such a manner that the activation of one alarm will
activate all of the alarms in the individual unit. The alarm
shall be clearly audible in all bedrooms over background
noise levels with all intervening doors closed.
1. Interconnection is not required in buildings that
are not undergoing alterations, repairs or construction
of any kind.
2. Smoke alarms in existing areas are not required to
be interconnected where alterations or repairs do
not result in the removal of interior wall or ceiling
finishes exposing the structure, unless there is an
attic, crawl space or basement available which
could provide access for interconnection without
the removal of interior finishes.
4603.7.3 Power source. Single-station smoke alarms shall
receive their primary power from the building wiring provided
that such wiring is served from a commercial source
and shall be equipped with a battery backup. Smoke alarms
with integral strobes that are not equipped with battery
backup shall be connected to an emergency electrical system.
Smoke alarms shall emit a signal when the batteries are
low.Wiring shall be permanent and without a disconnecting
switch other than as required for overcurrent protection.
1. Smoke alarms are permitted to be solely battery
operated in existing buildings where no construction
is taking place.
2. Smoke alarms are permitted to be solely battery
operated in buildings that are not served from a
commercial power source.
3. Smoke alarms are permitted to be solely battery
operated in existing areas of buildings undergoing
alterations or repairs that do not result in the removal
of interior walls or ceiling finishes exposing the
structure, unless there is an attic, crawl space or basement
availablewhich could provide access for building
wiring without the removal of interior finishes.
