Wood framing/wood roof structure for 1 story commercial building?
palikona
Colorado
Hi,
All of my previous commercial new build experience has been with buildings built with steel, CMU, concrete and metal studs. I'm beginning a project which is a 1 story dental office, with a 6000sf footprint. The roof will be flat with parapets around, and there will be a full basement as well. My structural engineer is recommending building this in wood (exterior wall and roof structure). Is(are) there a code section(s) I need to check in order to make sure this is acceptable? And do I need to discuss this with the local municipality early on to make sure it's ok?
Thanks for the help.
Rick18071
Sawhorse
Poconos/eastern PA
Per 2016 IBC A dentist office would be occupancy B. All wood construction would be construction type VB A non sprinklered building like this can be up to 9.000 sq feet and 2 stories. It could be even bigger it there is empty space around it.
Of coarse there may be local laws that are stricter.
palikona
Colorado
Hi,
Thanks for the post. I see that in Chapter 5. Does 9,000 sf refer to the max footprint for 1 floor or the max area of the whole building? The project I’m working on is 6,000sf on level 1, with a 6,000sf basement. I guess it will need to be sprinklered, correct?
Paul Sweet
Sawhorse
Richmond, VA
2018 IBC 506.1.3 says:
"Basements need not be included in the total allowable floor area of a building provided the total area of such basements does not exceed the area permitted for a one-story above grade plane building."
The old height/area table used to specify that it was area per story. When ICC split the tables they complicated the allowable area calculation. Unfortunately, I have forgotten my college calculus, so I can't figure it out anymore :(
