George McGerd
Bronze Member
Ok Gurus --- IRC 2012 Chapter R312 requires exterior guard rail components to comply with Section R317.4, which states: "Wood/plastic composites used in exterior deck boards, stair treads, handrails and guardrail systems shall bear a label indicating the required performance levels and demonstrating compliance with the provisions of ASTM D 7032."
Section R202 defines wood/plastic composites as: "A composite material made primarily from wood or cellulose-based materials and plastic."
Anyone have experience with someone applying this labeling provision required under R317.4 to wood (e.g. preservative treated) or plastic (e.g. vinyl railings)?
Any information / interpretations would be appreciated.
Also, is there a similar provision in the IRC for guards to be able to withstand 50 LF uniform and 200 lb concentrated lateral load (as there is in the IBC)? If so, please point me in the right direction. I don't always do residential design, but when I do……I want it to meet code.
