Wood wall framing: King studs and Jack studs
leothebuilder
Phoenix, Arizona
Per the 2015 IRC the number of king studs and jacks studs for a header are to be per Table 602.7.5
This table requires 6 full height (king studs) at each side of a 16'-0" span header where walls studs are at 16" o.c.. If you add to that 2 jacks studs to support the header with 3" bearing you have 8 studs at each side.
That just does not make any sense to me at all.
Especially if the same table specifies 4 king studs when wall studs are at 24" o.c..
Am I reading this correctly?
You have to look at the other chart that is referenced there.....For the 16 or 24 O.C.....But it is still alot of wood...
I did not see another chart.
I did check the 2018 IRC and this same table has greatly reduced requirements for full height studs.
A 16 feet opening only requires 2 king studs for wind speed design less than 115 mph.
Makes a lot more sense.
