Work in Hallways of Commercial Building
State or Country
USA
Owner - Contractor - Design Professional
Other
In a mid- or high-rise commercial building the owner wants to update the common hallways with the following work:
  • Replace carpets
  • Replace wallpaper
  • Replace suspended ceiling
  • Replace all lighting fixtures in the ceiling and sconces on the walls
What would you issue a permit for?
Not to hijack the thread, but we're dealing with a plan checker who is arguing that there is no such thing as a "hallway" - only "corridors". My piggyback question would be "Would it make any difference if it was a a hallway (or non-rated) or corridor (rated)?
PA UCC that takes the place of IBC chapter 1 does not require a permit for carpeting and papering.
Painting, papering, tiling, carpeting, cabinets, counter tops and similar finishing work is exempt.
  • Replace carpets
  • Replace wallpaper
Assuming the corridors are exit access corridors, the floor, wall and ceiling finishes are regulated so I would issue a building permit for that work. The owner has the option of using the Prescriptive Method or using the Work Area Method and classifying it as a Level 1 alteration.
For the lighting fixtures, that would require an electrical permit.
