mtlogcabin
You would be correct it would need to be CPVC to meet temperatureglobe trekker said:I don't believe that the regular pvc is allowed on the T & P drain line, because it is not rated for thosehigh of temperatures. See Section P2803.6.1, No: 13, and Table P2904.5 in the 2006 Edition of the
IRC.
Agreed...that's an air break, not an air gap. Although I don't think it's asking for an air gap for the same reason as a plumbing fixture (funk growing up on the outlet of the fixture). An air break, I think, would be sufficient, and sufficient for freeze protection. My only guess for the full air "gap" would be so it is readily visible that it's discharging while in the same room as the equipment.Uncle Bob said:No air gap.
I don't know about the UPC; but, 2009 IRC, P2803.6.1 The discharge piping serving a pressure-relief valve, temperature relief valve or combination valve shall: #2. Discharge through an air gap located in the same room as the water heater.Glenn said:Agreed...that's an air break, not an air gap. Although I don't think it's asking for an air gap for the same reason as a plumbing fixture (funk growing up on the outlet of the fixture). An air break, I think, would be sufficient, and sufficient for freeze protection. My only guess for the full air "gap" would be so it is readily visible that it's discharging while in the same room as the equipment.
I have heard of that and never seen it done except with commercial and a mop/floor/laundry sink. Even with commercial we allow a direct shot to the outside. I didn't find the requirement in the UPC and we don't enforce the IRC plumbing code.Uncle Bob said:#2. Discharge through an air gap located in the same room as the water heater.
Air gap only required when draining to the sanitary drainage to prevent a cross connection, it can #5 Discharge to the floor, to the pan serving the water heater or storage tank, to a waste receptor or to the outdoors.ICE said:I have heard of that and never seen it done except with commercial and a mop/floor/laundry sink. Even with commercial we allow a direct shot to the outside. I didn't find the requirement in the UPC and we don't enforce the IRC plumbing code.Anybody know why this air gap is a good idea?
Good question.Gregg Harris said:Air gap only required when draining to the sanitary drainage to prevent a cross connection, it can #5 Discharge to the floor, to the pan serving the water heater or storage tank, to a waste receptor or to the outdoors.
