Would you fail this?
Worth writing up or not?
Re: Would you fail this?
Yes! The romex needs to trimmed back and what I can see is a spaghetti factor starting.
Last, I don't approve OSB set direct to block or poured foundations. It tends to fall apart with just a little water. Then the panel is waving in the air not secured. Put a few treated 2x4 behind it and it is fine.
Are the wires fasten above the box or just held in place by gravity?
