What does your question have to do with a dwelling unit? Is it attached to a residence or is it a pool house on a condo site or other?
It is a swimming pool code requirement
305.4 Structure wall as a barrier.
Where a wall of a dwelling or structure serves as part of the barrier and where doors or windows provide direct access to the pool or spa through that wall, one of the following shall be required:
1. Operable windows having a sill height of less than 48 inches (1219 mm) above the indoor finished floor and doors shall have an alarm that produces an audible warning when the window, door or their screens are opened. The alarm shall be listed and labeled as a water hazard entrance alarm in accordance with UL 2017. In dwellings or structures not required to be Accessible units, Type A units or Type B units, the operable parts of the alarm deactivation switches shall be located 54 inches (1372 mm) or more above the finished floor. In dwellings or structures required to be Accessible units, Type A units or Type B units, the operable parts of the alarm deactivation switches shall be located not greater than 54 inches (1372 mm) and not less than 48 inches (1219 mm) above the finished floor.
Should the alarms also sound in the primary residence?
It does have direct access to the pool as does the main house, right?
Is the unit to be a B&B or ADU? Used by owner's kids or relatives? the houses occupants need to be aware of a user of the unit have fallen in, no?
contractors will still have to explain the expense of safety disconnects, especially in locations where it’s not common practice to add outdoor service panelboards
This one will
https://www.diycontrols.com/p-6121-pool-patrol-doorgate-alarm-wwireless-remote-receiver-ga-30.aspx
Overview
The Pool Patrol Gate & Door Alarm is a wireless door/gate monitor that detects entry into your pool or spa area. It is equipped with a reset button to allow a six second pass through without sounding the alarm. The alarm comes complete with all the necessary mounting hardware for installation.
An alarm will sound both at your gate/door and in your house up to a distance of approximately 200 feet. The remote receiver has an on/off switch with an "on" indicator light and is powered by a 120 volt A.C. wall transformer. Gate Alarm is Battery powered and uses one 9 volt alkaline battery (battery not included).
Custom outdoor additional passthrough buttons or Remote Receivers are also available for special order (contact us for details). Note that special orders may take 5 to 10 business days to ship.
Adjustable delay, choose 0 seconds or 7 seconds
The web site does not say it is UL2017 so it can't be used. Also no one answers the company phone.
Not true the AHJ can approve its use under alternate means and methods
Require a UL2017 alarm in the Cabana addition to this one to notify the occupants of the house
There is no code requirement to have them interconnected from the cabana to the house but we all see the need to have this done. So make it an easy solution and a simple suggestion where spending another $150.00 might save a child's life and unwanted grieve for the adults that left a child sleeping in the cabana while they went and had lunch
