lpiburn
Silver Member
I think I've entered a state of "cognitive dissonance". Old school building, technically "B" occupancy because it is above 12th grade. The building has a ton of problems and should probably be condemned (it is over 50 years old, wood framed and way over area, etc.) but I am getting questions on one item specifically. Here are some pictures of the outside doors. This is typical for EVERY SINGLE exit door in the building.
I am doing a review on the building but I am not the AHJ. I commented that all doors violate egress because of "improvised locking devices". The response was "these are only locked after hours". At first I was incredulous. Of course you can't do that, I thought. But then I took a closer look and I think they may have a loophole. Since this is a "B" occupancy, panic hardware is not required. IBC 1008.1.9.3.1 In buildings in occupancy Group A having an occupant load of 300 or less, Groups B, F, M and S, and in places of religious worship, the main exterior door or doors are permitted to be equipped with key-operated locking devices from the egress side provided: 2.1. The locking device is readily distinguishable as locked;2.2. A readily visible durable sign is posted on the egress side on or adjacent to the door stating: THIS DOOR TO REMAIN UNLOCKED WHEN BUILDING IS OCCUPIED. [...]; and2.3. The use of the key-operated locking device is revokable by the building official for due cause.It sounds stupid in my head, but doesn't a padlock like the one in the photos satisfy the requirements? If so, 1. Could they be in compliance just by adding signage?2. Does this just hinge on the graspability requirements for door hardware? (that seems like pretty flimsy reasoning compared to the dangers of lockable egress doors)3. Would this fall under the provision of 1008.13.9.4 for bolt locks? (there are still some exceptions here they might be able to use such as the under 50 persons exception)By the way, those black things on the photos are there so the staff can shove a bent steel bar across the opening, just to make extra sure the door doesn't get opened. I'm pretty confident THAT is a blatant violation, but the padlock has me wondering.Thanks in advance for any advice on this one.-LPView attachment 1959
/monthly_2013_10/SANY0418_resize.jpg.87b2693d63b2ca9a25d1892b93a331f8.jpg
/monthly_2013_10/SANY0468_resize.jpg.0a1a072716f4cffb37f7fba1e61f8e92.jpg
