You can't fit as many wires in schedule 80 PVC as you can schedule 40 PVC conduit of the same size
Someone check my math. Are you aware of this?
To illustrate a situation where a wire could fit into a 1.5-inch Schedule 40 PVC conduit but not into a 1.5-inch Schedule 80 PVC conduit, according to the NEC, let's consider a 4 AWG THHN/THWN copper wire.
The approximate area of a 4 AWG copper THHN/THWN wire is about 0.1293 square inches per conductor. According to the NEC, the conduit fill should generally not exceed 40% for more than two conductors.
The approximate internal area for 1.5-inch Schedule 40 PVC conduit is 1.767 square inches, while for 1.5-inch Schedule 80 PVC conduit, it's 1.443 square inches.
Schedule 40 PVC Conduit:​
  • Maximum fill would be 1.767×0.4=0.70681.767×0.4=0.7068 square inches.
  • Number of conductors that can fit: 0.7068÷0.1293≈5.460.7068÷0.1293≈5.46.
  • Rounding down, 5 conductors of 4 AWG could fit into a 1.5-inch Schedule 40 PVC conduit.
Schedule 80 PVC Conduit:​
  • Maximum fill would be 1.443×0.4=0.57721.443×0.4=0.5772 square inches.
  • Number of conductors that can fit: 0.5772÷0.1293≈4.460.5772÷0.1293≈4.46.
  • Rounding down, only 4 conductors of 4 AWG could fit into a 1.5-inch Schedule 80 PVC conduit.
So in this example, you could fit 5 conductors of 4 AWG copper wire into a 1.5-inch Schedule 40 PVC conduit, but only 4 conductors would fit into a 1.5-inch Schedule 80 PVC conduit, all while complying with the NEC guidelines.
I don't understand the context of this post.
Pipe keeps a consistent I.D....Tubing does not, as wall thickness changes, so does the ID of tubing...Hence EMT ENT...seems like conduit runs like tubing not pipe...So it makes perfect sense, and you gave a great real world example....
Jar:
You are correct that schedule 80 has a smaller inside diameter than schedule 40.
PVC Conduit for Electrical Wiring
Phil, the couplings and fittings for schedule 40 and schedule 80 PVC are the same size, here’s why:
Differences Between Schedule 40 and Schedule 80 PVC Conduit
  • The inside diameter is smaller with schedule 80 PVC because the wall of the conduit is thicker.
  • The inside diameter of schedule 40 PVC conduit is larger because the wall of the conduit is thinner.
  • The outside diameter of both SCH 40 and SCH 80 is the same.
Selecting the Right PVC Conduit for Electrical Wiring
  • PVC Conduit for Electrical Wiring – (Poly Vinyl Chloride).
  • PVC conduit is commonly used for underground electrical wiring.
  • The gray color makes it easy to identify Electrical PVC Conduit.
  • Schedule 40 PVC is the most commonly used for underground wiring.
  • Schedule 80 PVC has a thicker wall to provide more protection to the electrical wire.
    Schedule 80 PVC is commonly used in above ground applications where the conduit is vulnerable to damage.
