Has anyone dealt with a yurt?I am concerned about snow loads,wind bracing,fire ratings,energy code,etc.They do not meet the residential codes.Is anyone doing code modifications to allow them to be built?Any information would be appreciated.
In 2017 a client wanted to build a short deck wit a Yurt on it for "Family gathering" purposes and for a dry place for the kids to play. After reviewing the local zoning codes and the building code I confirmed that a structure less than 200 SF did not require a Building Permit but still needed to meet zoning setback requirements. In addition, a deck that is less than 24-inches A.F.G. also does not need a permit and can be build in the setbacks.They also wanted to have a heat source such as a small heat pump. I too was unsure as to the code language so after speaking to several plans examiners it was suggested that I apply for a Building Code Appeal to clarify. The effort was successful and the Yurt was built on a 24-inch high deck platform with a heat pump. i realize that some of these issues are local zoning code decisions but they worked for us. As to Snow Loads, this is a "Tent" and is not designed to support much load. I hope this helps. Cheers! EdskiHas anyone dealt with a yurt?I am concerned about snow loads,wind bracing,fire ratings,energy code,etc.They do not meet the residential codes.Is anyone doing code modifications to allow them to be built?Any information would be appreciated.
