If you are inspecting an electrical service upgrade and there is a swimming pool, do you ask for GFCI on the light and pump motor(s)?
So that we can have a starting place to consider & review, what Code, Editionand Section(s) are you referring to sir ?If you are inspecting an electrical service upgrade and there is a swimming pool,do you ask for GFCI on the light and pump motor(s)?
110.3(A)(8) works fine.~ @ ~Article 110.3(A)(8), from the `11 NEC, would, ...IMO "require" the
GFCI protection to be installed with a Service upgrade.
I do not know which Section in the `16 Tiger Code applies, as I
do not have access to that particular code.
Clarification on topic: electrical service upgrade
Does an electrical service upgrade include the Main Panel if it is being replaced or upgraded? If so does the residence get interconnected smokes, AFCI's and all the receptacles that require GFCI's get replaced?
If so that's brutal. we would't be getting the 60amp and 100amp Main Service Panels changed out here at all.
I always do. Sometimes I get pushback but it is obvious that the pump motors have been changed out several times on a thirty year old pool and no permits were obtained. I tell them that and the complaint floats away.Lets bring the pool and spa up to code also.
When I see the new breakers I ask what happened to the GFCI breakers that were in the existing panel. I am told that there were none. I remind them that they removed the power to the pumps and lights....Shirley they want them to work again and meet code. What else would we allow to be removed and replaced with an electrical code violation?
