Mr. Inspector
I just started working as the Building Code Official for a township that has apparently been requiring permits that the UCC has excepted for a long time for residential. The previous BCO was doing these inspections. The township has no ordinance requiring these permits or has any changes to the UCC. I pointed out to the township manager that these things are excepted from permits and showed him the sections in the UCC. . But I don't want to make waves, I just started here. So I'll do want they want me to do and go out and do the (exempted)inspections. I am required to inspect complying with the UCC. So if I see something not to code do I make them repair it or just leave it go? What would you do?
Examples: Two patios with nonconforming natural stone steps between them. Finished basement with ceiling too low. Finished basement with no insulation. Bedroom in basement with no emergency escape. Deck under 30" with a nonconforming stairway.
The UCC (Uniform Construction Code) is the law of the land here in PA that adopts the ICC codes and exempts any work on houses that have no structure (load bearing) alterations and decks under 30".
