Who said they aren't compliant? If mounted within reach ranges and projecting less than 4" and equipped with accessible pulls the cabinets can be accessible.
The extinguisher is a movable object, its use up to the users ability to chose to or not.
It depends on the whether its use is a job function or not.
NoDoes Ada have cam lever vs recessed pull or handle ??
The OP "Anyone hear about fire extinguisher cabinets going away??" said nothing about Surface vs recessed cabinets just "cabinets".Surface mounted cabinets may project too far from the wall surface where in the egress path.
Recessed cabinets are designed to mitigate that where necessary.
