So i recently did some renovation work in my basement and did some wood paneling over the existing dry wall and just cut the boards around the wall outlet. Well the tv is wall mounted and just so has it the cord drops neatly behind the wood paneling and plugs into the outlet. My question is can i put a blank wall plate on the wood paneling covering the outlet with the tv plugged in to make it look nicer or do i have to pull the outlet, outlet box, and plate out or leave it recessed and uncovered? Covering it with the blank wall plate still makes it technically accessable correct?
