Hey guys i would like to thank anyone in advance who can help.
Should a sprinkler pipe or 2 be running beside stud vertically to each sprinkler head ?
I hit a pipe in a new-ish condo. It was a dividing wall with no other utilities on either side, so no real reason to suspect pipe other than a popup up sprinkler head 11 inches to the right up top. It is the first time i have seen a fire system that does not distribute from the ceiling to the sprinklers unless there was good reason. I should also note that it was the top floor, maybe this is why ? I am aware that if you run a pipe between studs that it should be centered, is this code though ?
Any input on this subject is much appreciated.
