Brent b
when framing out an opening for a barn door slider are Jack studs required to meet code since there is no actual impact at the opening
Welcome !!
How did you find us??
I googled the question and this forum popped up. would you happen to have an answer
I do not do houses give it a couple of days, most on the forum take the weekend off.
Which building or residential code and year edition are you designing to??
Helps with the question
Yeswhen framing out an opening for a barn door slider are Jack studs required to meet code since there is no actual impact at the opening
I do not agree
yes "Jack Studs" must be used !
