What code section? IBC Table 1607.1 2012 IBC
5. Balconies and decks h Same as occupancy served
h. See Section 1604.8.3 for decks attached to exterior walls.
1604.8.3 Decks.
Where supported by attachment to an exterior wall, decks shall be positively anchored to the primary structure and designed for both vertical and lateral loads as applicable. Such attachment shall not be accomplished by the use of toenails or nails subject to withdrawal. Where positive connection to the primary building structure cannot be verified during inspection, decks shall be self-supporting. Connections of decks with cantilevered framing members to exterior walls or other framing members shall be designed for both of the following:
1. The reactions resulting from the dead load and live load specified in Table 1607.1,
or the snow load specified in Section 1608, in accordance with Section 1605, acting on all portions of the deck.
2. The reactions resulting from the dead load and live load specified in Table 1607.1, o
r the snow load specified in Section 1608, in accordance with Section 1605, acting on the cantilevered portion of the deck, and no live load or snow load on the remaining portion of the deck.
2012 IRC
Balconies (exterior) and decks e 40
e. See Section R507 for decks attached to exterior walls.
If you require more than a 50 psf total (live & dead) loads than you cannot use the IRC 507.2
