Oh Well
Shirley there must be a code section for the bending radius of wire. I wrote a correction that asked for a four inch radius. An inspector has challenged me to provide a code section. I don't have a picture of the wire but it must have been too tight so I wrote the correction.
Today I encountered the same violation and that's the pictures here. As you can see there is damage to the insulation. What you can't see is possible damage to the insulation on the other side of the bend. If there is damage there, it is against the metal enclosure. So I can write a correction for the damaged insulation but what about the bending radius. I can bend that size wire just as tight without damage to the insulation.
Section 300.34 is the only place that I have found with a code for wire bending radius but that section applies to over 1000 volts. What I am dealing with is 2/0 wire in service panel enclosures.
The radius here is that of a nickle.
If there is no code it must not be a problem, which suits me just as well.
