Welcome to the new and improved Building Code Forum. We appreciate you being here and hope that you are getting the information that you need concerning all codes of the building trades. This is a free forum to the public due to the generosity of the Sawhorses, Corporate Supporters and Supporters who have upgraded their accounts. If you would like to have improved access to the forum please upgrade to Sawhorse by first logging in then clicking here: Upgrades
panel door gives you access to the circuit breaker switches, but that's all. And that's as far as most homeowners need to go. However, to get inside the panel to install or replace a circuit breaker you have to remove the protective cover around the breaker switches, known as the dead front cover. The dead front cover is typically held in place with a screw in each corner. Removing the cover provides access to all components of the panel. Some panels have a separate door and cover; others have a door and cover as parts of the same unit.
You don't want your wires and connectors ever exposed to accidental touching.
Is that your concern?
Or accidental or purposeful tripping of the breakers.
