Is this a Dwelling unit under the ADA?In dwelling unit, what is the typical distance required between lavatory/water closet? I would like to know the requirement for both ADA and non-ADA (the project my firm is building is based on IBC 2012).
I believe Fair Housing Act
That's why I ask......What kind of "dwelling unit"?ADASAD covers government dwelling units, college dormitories, hotels & motels, including extended-stay motels, all of which which are similar to apartments.
ADASAD 604.3.2 Exception allows a lavatory to be 18" from the CL of the water closet in a residential dwelling unit. Otherwise a 5 ft. wide clear space is required at the WC.
In CA onlySee 1127A.3 of CBC for lavatories.
You started out with ADA "stuff"; 18" may not be the correct number for ADA.I'm not sure what you mean by what type of dwelling unit, but my question is simply what is simply what distance is required in residential dwelling unit b/w lavatory and water closet.. I believe the 18" answers my question
