They can also do ceiling notification devices.
I got to believe ceiling strobes can be incorporated into your project. More visual devises may be required for good coverage.
I have the same question for the same kind of place. 2007 NFPA says the strobe alarms are to be between 80 and 96 inches. Many places in this building they would not to be visible at these heights. Is there a section in this code that let's you have them somewhere else? Would you still need the strobe between 80 and 96 inches but can add more at different heights?
Ceiling is over 96" (40' in some areas).I got to believe ceiling strobes can be incorporated into your project. More visual devises may be required for good coverage.
Some would need to be higher and some lower and in some areas both.
I didn't know about the performance method, anyone ever use this?
Some of the conveyors are hundreds of feet long and 4 or 5 could be next to each other, so moving it to the side would not work. The ceiling is to high.
Could you get a code modification to use a later edition of NFPA 72 which has other height options?
Thanks cda i'll have to check that.
Doing building code inspections on a new building. Largest and most complicated I ever did.
They would have win an appeal to use a newer code book.
Plans where reviewed and passed a couple of years ago. The plans of the building do not show the conveyors which are on a different permit and set of plans. The building is 90% finished and the conveyors are 50% finished. As the conveyors are being built they block the strobes and so the strobes would have to be moved above and below the required height by the NFPA.
Just want to know how to proceed on inspecting the fire alarms if they can't be where the code requires them.
Just try to check the plan.
