Meadowbend99
I had a violation on a project for the sink, which is an ADA compatible sink and installed properly in a single restroom.
(Me)
1. (307.2) You noted a violation for a protruding object in the Restroom, showing the wall mounted toilet lavatory. It has been my understanding that this refers to objects within the circulation path. A circulation path is defined as An exterior or interior way of passage from one place to another for pedestrians, typically referring to walks, hallways, courtyards, elevators, platform lifts, ramps, stairways, and landings, which would not include a restroom.
(Inspector)
The full definition of a circulation path per 2012 TAS states:
106.5.19 Circulation Path. An exterior or interior way of passage provided for pedestrian travel, including but not limited to, walks, hallways, courtyards, elevators, platform lifts, ramps, stairways, and landings.
Our office has previously submitted numerous questions to TDLR technical information, the state agency that enforces the 2012 TAS, concerning this issue and the response has been the same. The path from the water closet to the lavatory in a restroom is considered a circulation path and if the bottom leading edge of the lavatory is mounted above 27” it is a protruding object for the visually impaired. The words “including but not limited to” in the definition of a circulation path would include the path from the water closet to the lavatory in a restroom.
If you've come across this before what are you advising your clients to do? Lower the lavatory so that the bottom of the bowl is at 27"? Install a skirt around it?
(Me)
(Inspector)
