easily recognizable doors
Mr. Inspector
Poconos/eastern PA
IBC 1008.1 Means of egress doors shall be readily distinguishable from the adjacent construction and finishes such that the doors are easily recognizable as doors.
Can you see 5 doors? Does this comply? If it doesn't how would you fix it?
"Easily recognizable" no
Recognizable only by the exit signs, which would be covered by smoke
there is an exit sign there
Rick,
One suggestion might be to add extremely large, bright, fluorescent
red or green stenciling on to each Exit Door with the lettering stating
"This Is An Exit Door".....Also, install some color matching,
heavy duty pedestrian traffic tape in the shape of a square directly in
front of each Exit Door......Something that will contrast greatly with
the surrounding doors \ glass.
Replace the exit signs that are flat against the wall with signs at right angle to the wall.
Reflective tape around opening. Had one that had a picture for tint and hard to see which were doors & Windows. Had them remove from doors.
