Retrojoe_1
I've been having a few problems with the contractors who have started building my garage. I had plans drawn up and stamped that called for a 4-inch reveal of wall above the finished garage floor. I believe in the plans the engineer specified "drop foundation 8in for a 4 inch slab" which I suppose translates to the 4-inch reveal. Anyways, when they got done with the floor it is only an inch from the top of the frost wall in the back of the garage and an inch and a half at the front. They used a pressure-treated sill plate for the framing, however now you have the OSB and the rest of the untreated Lumber only an inch from the floor. I told them that this is not what I wanted and they told me not to worry about it. An engineer told me that the untreated Lumber is so close to the garage floor that it could Wick moisture and rot prematurely. On the outside of the garage the grade around the foundation wall varies but in some spots it's as close as an inch and a half to the OSB sheathing. I suppose this could be dug away and stone could be put in around the perimeter. They poured a small slab on the outside of the garage right in front of the entry door. Somebody told me that the top of that could be considered grade and if so it's only a two inch distance from the top of that slab to the sill plate . If that is considered grade then they would be in violation of code because as I understand it the top of the foundation wall needs to be 6in from grade. And what about the inside? Is this a code violation of any means? Does anybody have any thoughts on this? I'm just really ticked off and not sure that there's a solution at this point.
