nealderidder
Sawhorse
CBC 510.2 addresses podium buildings. What the podium is rated, what can go beneath it, what can go above it etc. One paragraph has me scratching my head:
"6. The maximum building height in feet shall not exceed the limits set forth in Section 504.3 for the building having the smaller allowable height as measured from the grade plane."
Quite often we do podium buildings as a way to get a commercial use on the ground floor and then max out an R2 use above. The R2 is usually wood or light metal framing (4 or 5 stories).
Per 510.2.2 the building below the podium must be type IA. The building above will likely be Type V or IV. The allowable height for a IA building will be much greater than a Type V or IV. So if I re-write that sentence with a little substitution I get:
"6. The maximum building height in feet shall not exceed the limits set forth in Section 504.3 for the building above the podium"
Is my substitution correct? What exactly is this paragraph trying to regulate? Is this implying that the building below the podium can exceed the height limit in 504.3? I just don't get the purpose of this one sentence.
Can somebody help me understand?
Thanks,
Thanks,
