Actually, yes it is. A horizontal exit is an exit.“””The third required exit is the horizontal exit.””
Ah NO!!!
Ah NO!!!
That goes to interpretation as I mentioned previously. All the technical aspects of a horizontal exit are incorporated except for some minor refuge area calculation errors and that nebulous "divide completely" phrase in Section 1025.2.I agree but in this scenario
Not a third exit
To me there are only two exits
The stairs
Read the definition in Chapter 2: "An exit component consisting of fire-resistance-rated construction and opening protectives intended to compartmentalize portions of a building thereby creating refuge areas that afford safety from the fire and smoke from the area of fire origin."Well
""A horizontal exit may be an element of a means of egress when in compliance with the requirements of Section 1025.1"""
It is not an exit, it is basically a way to an exit, because you still need an exit path on the other side to discharge.
Interesting vide. I disagree with his first element in regard to the termination of a horizontal exit at an exterior wall. What he shows is required of a fire wall, which can be considered a horizontal exit. However, when constructed as a fire barrier, the termination of a horizontal exit need only comply with the requirements for fire barriers at exterior walls.
