Green-rev
I have a project where we built a porch in front of an existing block building. It was built using a studwall against the block building with posts and headers on the outside wall. The studs were supposed to have been put tight against the building, but because of some pilasters on the building, the contractor laid the wall out with the outside of the studs flush with the outside of the pilaster. The studs were then sheathed with plywood. The AHJ would not do an inspection until after the sheathing was applied, and during the inspection he said that the wall would need fire-blocking. Needless to say, this has caused some consternation, as now the sheathing is going to need to be removed in order to properly fire-block. The question I have is does that wall need fire-blocking? It is only supporting the roof of the open porch. There is a foyer that was also built in front of the entry door, and that is fire-blocked. There is nothing combustible directly above the porch stud wall on the existing block building, it is just a flat wall with no overhangs or projections. Is there any arguement to be made to not require the fire-blocking?
