In Use Cover for Exterior Balcony Receptacle
I did not know that. Do they make one that doubles as a door stop?
But without the cover open it is not that easy to discern, you wouldn't know that the receptacle isn't recessed in there....Maybe you could explain the dead giveaways on the exterior of box such as the threaded plugs that would let a person that is not an electrical god know that "hey, maybe I ought to take a closer look at this" because it looks like a surface mount box, not an extension that would be set up for in use....
Understood. Based on the materials used for this installation, it is obvious that it is not an in-use cover. You can't recess a GFCI receptacle inside a single gang exterior metal box and yes, the plugs are a giveaway. Bubble covers are much more obtrusive.
If the hole in the wall was just a little bit larger the box could be recessed. Given how this turned out, you should require that.
Is the hole behind the box code compliant? If I can toss a cat though the gap.... I think not.
As it sits now, the door will miss the box and it’s cover. If an I use cover is installed, the door will hit the cover. I find that to be unacceptable and I would seek a remedy. Since there is an obvious need for patch work, a recessed outlet is a possibility.
