Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,389
I have a new proposal for swinging gates used to discourage shoplifters at a major national retailer. They are proposed across the main exit aisles leading to the main exits. They swing freely when approached from the ingress side but are provided with a photo sensor that will sound an alarm when approached from the egress side, at which time they will not be free egress, but will require a force of 5lbs or less to push through. They are proposed to have "emergency exit-alarm will sound" signage. With this set up I don't see any inhibition in egress under emergency conditions, just a discouragement under normal operations. Assuming these gates do not reduce the required egress capacity does anyone know of any other requirement these would not meet? They can be wired to the fire alarm system but aren't proposed that way and when power is off they swing freely.
