Virginia Residential Code - R5 Use Group
tbz
Silver Member
PA/NJ - Borderlands
Morning all,
Looking for a directional question on which code applies.
A single family home with an attached garage, it is under 3 stories, the permit notes R5 Use Group / VB, this would fall under the adopted IRC, not the IBC yes or no in your opinion?
Morning all,
Can you post a link to the Great State of Virginia IBC/irc
It's a single family home with an attached garage, my question is directed at how in Virginia do you get to using the IRC, though the USBC (2012).
I went to the Virginia DHCD website which just lists a single "Virginia Construction Code" by year, reviewing that document under Section 101.2, note 2, it directs you to Section 310. and under 310.7 & 310.8 it directs Use Group R-5 to use the IRC and then under 310.11 it goes through the amendments.
Thus I am looking to verify that an R-5 Use Group is the trigger on a permit that send you to the IRC though 310.7 under the Virginia Construction Code.
Looks like you have it right
310.7 Residential Group R-5
Residential occupancies in detached single-family and two-family dwellings, townhouses and accessory structures within the scope of the IRC.
310.8 Group R-5
The construction of Group R-5 structures shall comply with the IRC. The amendments to the IRC set out in Section 310.11 shall be made to the IRC for its use as part of this code. In addition, all references to the IRC in the IBC shall be considered to be references to this section.
310.8.1 Additional requirements
Methods of construction, materials, systems, equipment or components for Group R-5 structures not addressed by prescriptive or performance provisions of the IRC shall comply with applicable IBC requirements.
https://up.codes/viewer/virginia/ibc-2015/chapter/3/use-and-occupancy-classification#new_310.7
