None, because its not designated as an accessible restroom.
Obviously the soap dispenser ... never seen that before. Side clearance on the sink.
And that is one of the reasons ANSI is not Law/CodeICC/ANSI A117.1 - 2009 section 606.78 Operable Parts on towel dispensers and hand dryers shall comply with TABLE 606.7.
Nothing about soap dispensers
Need a tape measure to check other things.
No tilt in ANSIThe mirror does not appear to have a tilt to it. What code / standard requires a tilt? I do not see the requirement in A117.1-2009; maybe I missed it.
people do that to try to get out of the lower reflective edge distance, but not required.
Also add the projection of the paper towel dispenser exceeds the 4" maximum allowed by ICC/ ANSI/ ADA. Hook on compartment door, self closing door, etc.
I would not call the paper towel dispenser a Protruding objects on circulation path
Good point. But when you have an inspection to see if the facility meets ada accessibilty requirements, then you do care. And being on the owner side, we need to be able to successfully defend against ada challenges. And unfortunately there are people who make a living doing that.As a PA inspector I don't care what the ADA says, I only inspect to the code.
