north star
- Joined
- Oct 19, 2009
- Messages
- 4,596
I have a project for new commercial construction,
whereas two existing, interior work bays will be converted
in to a 20' x 40' set of office spaces...….New wood framed
walls with new electrical, HVAC, Lighting, Comm. \ I.T. and
thermal insulation in the walls and above a drop ceiling.
There is a sufficient amount of restroom fixtures already
on the site...……..The applicable Codes & Standards are:
the `18 family of I-Codes, the `10 ADASAD & the `17
A117.1.
Wooden ceiling joists are planned for install above this
office area......I am not sure of the framing layout for
these ceiling joists as I do not have any actual plans \
drawings yet......It is in the "conceptual stage" of design.
I know that I will have to check the Span Tables for the
correct sizing of ceiling joists......I plan to do that after
I receive a Framing Layout.....Currently, there are no plans,
as I understand it, to have the area above the drop ceiling
to be used as storage, only as part of the framing below.
Q1): Should the area above these office spaces have a
minimum Load Rating, or is it even required ?
Q2): What thickness of plywood is required for this area ?
Q3): Are ADA \ Accessibility Standards required to access
this area ?
Q4): Is Guard Railing required for this elevated area ?
Q5): Is lighting required for this area ?
Q6): Does this area have a defined name according to
the I-Codes ?
Thank you for your input !
A117.1.
this area ?
the I-Codes ?
