ELLEN09US
Member
Does anyone knows if I need second exit for third floor?
Thanks!
Thanks!
The 500sf limit was an old UBC requirement. If built under the IRC no second exit required, however if built under the IBC a second exit may be required based on occupant load or common path of egress travel.I've heard 3rd floor more than 500 SF needs second exit but I can't find it in the code.
So ,there's a limit to the exit path not more than 50 feet.
R311.4 Vertical egress: For habitable levels........, the max. travel distance from any occupied point to a stairway or ramp that provides egress from such habitable level or basement, shall not exceed 50 feet.
does that mean from the 3rd floor to the exit door has to be less than 50 feet?
Thanks!
