Jonathan Earnhart
Is a thermal barrier required on a metal shop with spray foam under IBC Chapter 26? The shop is actually block with a metal roof. I used this exemption but the city says no:
Elimination of Thermal Barrier According to building codes, roof assemblies incorporating foam plastic insulation installed on a steel deck must include a thermal barrier, typically 1/2 inch gypsum board or equivalent, between the deck and the foam plastic insulation. The thermal barrier may be eliminated if the complete roof assembly passes either FM 4450 or UL 1256. Note that although both FM 4450 and UL 1256 are conducted on a specific roof assembly, passing either test without a thermal barrier in one tested roof assembly does not mean the thermal barrier may be eliminated in all roof assemblies. Specific roof assemblies that have passed FM 4450 may be found in the FM Approval Guide or the web-based FM RoofNav roof assembly search tool. Those that have passed UL 1256 may be found in the UL Roofing Materials & Systems Directory.
