Too Tired for BS
Does the first of these Code sections conflict with the other two? For context, see below.
Price Pfister used to manufacture a bathtub/shower rough-in three-handle component -- hot, cold and diverter valves -- that had shutoff valves underneath the hot & cold valves. Access to the two shutoff valves could be obtained by rotating the teardrop-shaped hot & cold escutcheons 90 degrees (which didn't require any tools). That accessibility presumably satisfied 606.3. The shutoff valves could be closed or opened using an ordinary flathead screwdriver.
Recently a plumber sealed the escutcheons to the wall with a silicone sealant, and now the escutcheons can't be rotated to access the shutoff valves. The plumbing company says Code required the plumber to seal the escutcheons. Here's an excerpt of their email:
Here are the two IBC sections cited by the plumbing company:
Do any of the above Code sections about seals or water-tight joints apply to the escutcheons in a condo? If the escutcheons must be sealed, is there a way to seal them that would block water adequately yet still allow them to be rotated? (Perhaps a teflon seal?) If there's a way to seal the escutcheons that would allow them to be rotated, is that what the plumber needs to do?
I'm also confused about which Code matters for our 8-story condo building in Montgomery County, Maryland. The county's website mentions the IBC and IRC, and when I google the IRC I get info about the International Plumbing Code. Is the IBC or the IRC the one that matters for condos, and does the IPC matter for condos too?
Section 606.3: Access to valves. Access shall be provided to all full-open valves and shutoff valves.
Section 405.6: Water-tight joints. Joints formed where fixtures come in contact with walls or floors shall be sealed.
Section 421.4.1: Floor and wall area. Bathtub floors, shower floors, wall areas above built-in tubs that have installed shower heads and walls in shower compartments shall be constructed of smooth, corrosion-resistant and nonabsorbent waterproof materials. Wall materials shall extend to a height of not less than 6 feet (1829 mm) above the room floor level, and not less than 70 inches (1778 mm) above the drain of the tub or shower. Such walls shall form a water-tight joint with each other and with either the tub or shower floor.
"Wanted to follow up per our conversation in regards to escustions issue on the tub shower wall being sealed. Our technician spoke with the manufacturer rep and did confirm that type of escustions that the owner is referring to is no longer in production. The last manufacturer to have this escustion was Price Fister and discontinued production 5 years ago. Additionally we have looked into the ICS (International Building Code) section 2511.5 of IBC titled “Wet Areas” has that wet walls and protrusions should be sealed. Also in the IBC Section 1210.4 it references that tubs are to be sealed to walls (tub wall joints are to be sealed)."
2511.5: Wet areas. Showers and public toilet walls shall conform to Sections 1210.2 and 1210.3. When wood frame walls and partitions are covered on the interior with cement plaster or tile of similar material and are subject to water splash, the framing shall be protected with an approved moisture barrier.
1210.2.4: Waterproof joints. Built-in tubs with showers shall have waterproof joints between the tub and adjacent wall.
