Sifu
- Joined
- Sep 3, 2011
- Messages
- 2,798
I have an existing building with multiple tenant spaces. Per plans the building has a 1-hr rated assembly for separation. Between two of the tenants a pocket door was added some time in the past. I can't be sure, but I believe it was added so that the two tenants could share bathrooms. The door opens to a set of 2 or 3 steps, without a level landing on each side. So I have a breached fire barrier, a sliding door that is not rated, self-closing or latching, no required landing, and a circulation path that is not accessible. The proposal is a B to B tenant finish, none of the work involves this area. The shared bathroom is addressed now because they are adding an accessible bathroom.
The IBC would have issues with all of it but does the IEBC give all of this a pass since none of it is in the "work area"? Would "unsafe" apply to the missing protected opening? How about the missing landing? Would the door between the two be considered a route to the primary function area (circulation path) and be required to be upgraded?
In general, do most existing violations get the pass if they are not in the scope of work...even if they were installed without a permit or in violation of the codes (but approved) enforced at the time they were constructed?
I know this has probably been debated before but I still have trouble wrapping my head around it.
