PatrickNYS
Hello everyone,
I would like opinions on the following:
The plan it to finish the basement. This is a link to a 3D rendering of the plan/situation. link to dropbox file
The issue: do I need to add a (larger) egress window?
Currently there is one window that is not big enough to qualify as and legal egress window but it is currently one open space and there is also a set of Bilco doors, and of course stairs that go to the 1st floor. Although replacing the window by a larger and code compliant one, is technically an option, practically it is a challenge because of the plumbing right under it that would be in the way and hard to reroute.
If I split the space into 2 spaces:
- room #1 (the right one in the picture) that is about 1/4 of the surface and has the Bilco doors as an exit, and
- room #2 that is basically one big room that leads to a hallway between the 2 spaces. There will be no door(s) between room #2 and the hallway. The hallway has unobstructed access to a staircase and the door at the top of the stairs that opens onto the first floor.
Would room #2 still need an egress window or does the direct access through the hallway to the stairs to the first floor count as an code compliant egress?
Thanks in advance for all your time and advice.
Cheers,
Patrick
Cheers,
Patrick
