The code allows a stair to exit into a lobby (vestibule?) area if certain exceptions are met. One of those exceptions is if "The area is used only for means of egress and exits directly to the outside". Would a Lobby area that exits directly to the outside but also allows folks to enter a building comply? What if the Lobby also has an elevator? Picture a small entrance Lobby to a Restaurant.
Also, if there is only 1 stair from the second level, then you have to go directly to the outside since you are exceeding the 50% rule, correct?
