KarlaE
That seems that path of least resistance....and I only have one bath exhaust...and it is at the far end of the living quarters, so running it 24/7 will not bring a "noise issue" - I will research what volume/rate will comply with the Mechanical Code mentioned previously in this thread so that I can purchase a fan to meet these requirements.As long as egress window is present in the bedroom, then the rest can be satisfied with artificial light and mech. ventilation. Easiest way to do whole house mech vent is to have one of the bath exhausts run 24/7 or a specific ratio - to provide the minimum required air volume per unit of time.
Ditto for the artificial lighting... I'll put in additional recessed lighting in the ceiling divided across several individual switches so that the lighting is there, but not all come on at the same time (I don't like a lot of light)
Thanks for your suggestion!
