metalfab
What should the minimum clearance be from the bottom of a pipe handrail to the top of the horizontal portion of the wall bracket?
Welcome to the forum,What should the minimum clearance be from the bottom of a pipe handrail to the top of the horizontal portion of the wall bracket?
It is a commercial building and we are using 1 1/4" std pipe with the bar bracket made of 5/8" dia. rod.Depends where you are using the handrail.
Is it for stairs in a commercial setting? Residential?
Look at what Tom wrote...He is the railing man.....It is a commercial building and we are using 1 1/4" std pipe with the bar bracket made of 5/8" dia. rod.
