Beniah Naylor
I occasionally run into the situation where someone is trying to replace an older water heater that was installed originally without a pan in a confined space. The new water heater will barely fit in the space, but the plumbers tell me that they can't find a pan that will fit into the space under the water heater - they are saying they have a 19" space and the smallest pan they are finding around here is a 20". 18" pans are available online, but really they are too small for the water heater in question.
The code allows galvanized steel or aluminum not less than .0236 in. thick, plastic not less than .036 in thickness, or "other approved materials" (IRC P2801.6).
What would you guys accept as a home-made water heater pan? Is there a shower lining material that would work? Field bent sheet metal pan? What is the easiest solution?
