A wake up call for sureI hope "Thou Soo Lucky" is okay?
Sears would give you a new one.Is that what's left of the Klein screwdriver in pick two? Are they guaranteed?
HelperLicensed electrician, right? What was he doing? Or trying to do.
The helper, may want to think about becomming a plumber!Helper
Shirley they were listed to be installed at a 45 degree angle......There's something not right about the breakers at units 804 and 805.
You think the 904 stack needs to be replaced?and going to be expensive to repair, at the very least 3 meter stacks need to be replaced,
ICE that would sure be a different way to go out, any body running around with a screwdriver and a pee spot on the front side of thier Bermuda shorts should be questioned, I'd think?Judging by where the screwdriver was placed, this was either sabotage or an attempted suicide.
A pee spot would be the least of it.....he looks like he got too close to the Sun.Do you think this was someone trying to do electrical work and they needed to or wanted to pull the meter? Maybe unit 703? The location of the screwdriver leads me to believe that they were trying to pry the meter rink off? Just my investigation instincts kickin in. Was there a tool bag near by or skate board? Fire apperars to be from the lower sockets?
I noticed you have a pee spot on the front of your shorts!, "Where were you on April 28th?"
