2nd story addition feasibility
kjmass1
Boston, MA
I have a 1940s home which at some point had a small addition added in the back. 2x4 walls on concrete foundation, 4”x6” header, 2x8 slightly notched floor joists, with brick fire blocking. I’m exploring adding a second story on top of this, or even possibly a third to tie in to the finished attic space. Can I work with this or will it need to be reinforced? Engineer will be scoped of course but just trying to gauge what I’m working with. Thanks!
The issues you mentioned are not going to be the biggest considerations.
For a multiplicity of reasons you will not find the solution in the IRC. What you need is an engineer to design the additions.
The picture provides enough information to suspect that a two story addition will start from the ground up with an engineered plan.
No it doesn't mean you have to tear everything down. The engineer will develop a solution that keeps as much of the existing as is feasible.
The issues start with the foundation. Your existing foundation is unknown. In my experience an engineer would specify a footing that does not exist. …..but I am in California and foundations are given extra scrutiny. Beyond the foundation is the underwhelming framing shown in the picture.
