You can also have gypsum sheathed shear walls.From an engineer's perspective the sheathing that is a part of a shear wall and consists of either plywood or OSB.
Snarky as ever. Why can't you be nice to the people that come here for advice. Mario started out with, "Entry level plans examiner here." and you just couldn't keep your big mouth shut.A plans examiner with this question would be well advised to talk to an engineer employed by the building department and should limit his efforts to the most basic sort of permits.
The existence of sheathing does not automatically make a wall a shear wall.
The basic concern is that the building needs to resist the horizontal loads resulting from significant wind or rom an earthquake. To be effective there must be a load path that allows the forces to be transferred to the foundation. The framing and hardware must allow the shear wall to resist overturning forces. If not the shear wall will tilt over.
While the IRC provides prescriptive provisions that address these situations for a limited set of buildings in general the determination of whether there is sufficient lateral resistance needs the knowledge of a professional engineer.
As well as you should too. It's not up to you to spank plans examiners.A plans examiner should know his or her limits.
You might want to dust off your SDPWS. Gyp sheathing has less capacity than plywood but not that much less. Also, you're typically counting both sides of a gyp shear wall unlike wood panels where you're often asymmetrical and cannot. Gyp shear walls are used all the time in wind country, often as you get to higher floors.Gypsum sheathing has very limited values and is seldom used by engineers. In addition when subject to earthquakes the nails crush the gypboard causing the lateral capacity of the gypsum panels to degrade very quickly.
Mario, go to the apawood.org and look for their free webinars on Braced Wall Panels - they will teach you a lot. APA stands for the American Plywood Association, they changed their name to "The Engineered Wood Association" but they still go by APA.Entry level plans examiner here. Basic question I couldn't get a clear answer from google. Difference between a shear wall and sheathing? Is the wall the framing itself supporting the sheathing? Thanks guys.
I don't know man, I think his answer was pretty good, and taken at face value I didn't see anything that was rude or not "nice."Snarky as ever. Why can't you be nice to the people that come here for advice. Mario started out with, "Entry level plans examiner here." and you just couldn't keep your big mouth shut.
Mario,
There was a day when the blowhard was not an engineer. He didn't know a shear wall from a shitter wall. Well he does now. He thinks that he's a big fish in a little pond. Tigers don't like fish....too bony.
I guess that first statement could be considered snarky, but he's not wrong. Maybe it could be "nicer" if he said "An entry level plans examiner..." and "and the supervisor should limit..."A plans examiner with this question would be well advised to talk to an engineer employed by the building department and should limit his efforts to the most basic sort of permits.
Great question from a new plans examiner to make sure you are doing your job properly and some great responses here in this thread to help you out. Welcome to the forum and the industry!Entry level plans examiner here. Basic question I couldn't get a clear answer from google. Difference between a shear wall and sheathing? Is the wall the framing itself supporting the sheathing? Thanks guys.
Maybe except the part where it's seldom used by engineers. If I see wood structural panel shear walls on the top floor of a III or V I know the engineer is being lazy.What I said about gypsum sheathing is still true.
Please excuse me.I don't know man, I think his answer was pretty good, and taken at face value I didn't see anything that was rude or not "nice."
I think you two need need some boxing gloves and a ring. <said with snark and sarcasm> The rest of us can grab some beer or popcorn and enjoy the show! I know I'm newer here and there's probably some history but I will say it's definitely entertaining! And educational, I've learned a lot from both of your posts.
Listen to him, are you ICC certified yet? Buy Ching's books for graphic clarifications .A plans examiner with this question would be well advised to talk to an engineer employed by the building department and should limit his efforts to the most basic sort of permits.
I guess I am to assume that ICC certification trumps being a licensed engineer with considerable experience with residential structures. My mistake.Listen to him, are you ICC certified yet? Buy Ching's books for graphic clarifications .
Good advice. I still reference handbooks for the odd thing today.Listen to him, are you ICC certified yet? Buy Ching's books for graphic clarifications .
Gypsum is used as part of a shear wall frequently in areas of the country outside of earthquake zones. There are specific nailing patterns called out by the licensed architects or engineers that design them. Sometimes we need to step outside of the little bubble we live in and realize that there are both round holes and square holes in this world. The world's axis does not rotate around the area we live in.Gypsum sheathing has very limited values and is seldom used by engineers. In addition when subject to earthquakes the nails crush the gypboard causing the lateral capacity of the gypsum panels to degrade very quickly.
Mark, it seems what you are saying is "being a Professional Engineer" trumps the ICC Certs. Many of us have spent the first part of our work-life trying to build what Some Puppy Engineer thought was a good idea! Remember what it was like Before you gained some real experience. Just like the new guy who asked that basic questionI guess I am to assume that ICC certification trumps being a licensed engineer with considerable experience with residential structures. My mistake.
If the ICC certificate is in the possession of a duly sworn plan checker then your assumption is entirely correct. That works with with certified inspectors also. But then you knew that.I guess I am to assume that ICC certification trumps being a licensed engineer with considerable experience with residential structures. My mistake.
