Tim Mailloux
2015 IBC, Two stories, type IIB construction, H use group, fully sprinklered building.
The client would like both required exits from the 2nd floor to be exterior egress stairs. Per 1027.6 exception #2 the exterior exit stairs are not required to be protected from the interior of the building. However as these are the only two exit off the floor they also both need to be accessible means of egress. Does that also mean both stairs would also need to comply with the requirements of exterior areas of assisted rescue which require fire separation and two way communication?
