Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,394
I had a conversation with a structural engineer a few days ago that illustrates a question I have had for a while. In this case, I had provided a comment that the ground snow load on his plan was not correct. He called and wanted to know what it should be. I said well, that would be as per ASCE 7 and the specific case study. He said, but it's listed on the AHJ website, and I said, no, it shouldn't be for commercial construction, that the only design criteria should be for residential. So he pulled up the website while we were on the phone and said "yeah, I see that now" and then asked about the CS I had.
Engineers using the residential design criteria for commercial construction is very common, but at least in my area, they are different. I am in a CS area, and the case study I have has the loads higher across the board. I also use the ATC website, and the ASCE 7 hazard tool website to verify loads when they don't look right. So for all the engineers out there, how do you arrive at a given design criteria for a project? Are you seeing AHJ adopted criteria for commercial construction? (not sure I ever have) Are you using the residential design criteria? Are you using the same resources I have access to?
